It is currently Thu Aug 21, 2025 9:22 pm
 Post subject: Clear pick guard
PostPosted: Thu Oct 31, 2013 9:29 pm
Last Name: Ensor
City: Springfield
State: Missouri
I have been trying to apply a clear pick guard- the self sticking mylar from stew mac- with less than satisfactory results. There are always tons of little bubbles under it. Any suggestions on how to get better results. I have tried both wet and dry applications. I am thinking about buying some thin clear plastic and gluing it on rather than using the precoated sticky kind. Thoughts?
http://elevatelutherie.com
http://ensorguitars.com
 Post subject: Re: Clear pick guard
PostPosted: Thu Oct 31, 2013 9:46 pm
Hey Chris,
If they are bubbles it's your technique and you'll just have to practice more. Make sure everything is clean, clean, clean! That includes de-linting yourself before application.
If it looks more like a reverse imprint of the grain, let it sit a few days and that will go away. Slight heating with a hair dryer after applying the guard can help speed the process along. Don't get the surface much more than warm to the touch.
PostPosted: Thu Oct 31, 2013 10:03 pm
Exactly. Unless its a full on bubble, all the light spots in the summer growth lines will disappear by themselves.
PostPosted: Thu Oct 31, 2013 10:45 pm
Use a little dishwashing soap in the water, and squeegy it out.
PostPosted: Thu Oct 31, 2013 10:48 pm
In the water?
PostPosted: Fri Nov 01, 2013 6:39 am
+1, a couple of drops in 200 ml (don't shake) here, spray on PG and top, large beveled eraser for a squeegee.
Don't get fingerprints on the adhesive!
PostPosted: Fri Nov 01, 2013 6:57 am
First name: steve
Last Name: barbour
Country: U.S.
Here's a good you tube video that may help.http://youtu.be/c9XKuourJs4
Kyle
These users thanked the author SKBarbour for the post: Mark Fogleman (Fri Nov 01, 2013 4:02 pm)
PostPosted: Fri Nov 01, 2013 1:29 pm
Last Name: Ensor
City: Springfield
State: Missouri
Thanks for the tips guys. I am now happy with it.
Alright, so here is my list of learned mistakes (hopefully it will help someone not repeat what I did):
Mylar doesn't route well (using a template)
Cutting mylar with an exacto knife leaves the edge nasty and it likes to peel up
Plain water doesn't work as well as water with a few drops of detergent
Dry application.... nope
Cutting with scissors ala the Frank Ford video mentioned is the way to go.
Thanks again for everyone's help.
PostPosted: Fri Nov 01, 2013 5:34 pm
First name: Trevor
Last Name: Gore
City: Sydney
Todd Stock wrote:
Almost all of our relationships begin and most of them continue as forms of mutual exploitation, a mental or physical barter, to be terminated when one or both parties run out of goods.
- W. H. Auden
As you change your quotes almost as often as you change your socks, Todd, I thought I'd "freeze" this one for a little longer.
So cynical, but so true.
http://www.goreguitars.com.au
PostPosted: Fri Nov 01, 2013 10:54 pm
I messed with the stewmac ones, scissors, etc, and was equally diappointed with the results. l now buy the tap plates from Ron Fernandez, and then have them laser cut. I can send anyone my CAD file if you like, and then you just need to find one of those guys that have a laser engraving business, to cut them for you and you will have awesome high quality clear pick guards. I use a guy in Calgary, for any of you Canadians.
PostPosted: Sat Nov 02, 2013 4:00 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
jason, who is r. fernandez? thanks
PostPosted: Sat Nov 02, 2013 5:57 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
http://www.fernandezmusic.com/
PostPosted: Sat Nov 02, 2013 9:26 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Thanks ok , yes I saw his name somewhere . I like wooden tap plates. But will check with RF for the plastique, merci
PostPosted: Sun Nov 03, 2013 10:12 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Chris , if you have the kinkead book on ss const . he uses a walnut veneer pickguard I don/t know if it/s glued or sticky sided.But IMHO like the look. I/ve noticed over many years (40) that clear pickguards curl up after X number of years attract dirt and dust under the curl and just my opinion look cruddy to my eye, just like plastic binding shrinks over time an cracks .It/s a judgment call on the part of the luthier. I/m guessing that on some tops , a clear pickguard would look better than a wood veneer What do you other luthiers do, and use ?? Just curious. Thanks.
PostPosted: Sun Nov 03, 2013 10:57 am
How does the stewmac material differ from the Fernandez? Laser doesn't melt the edges?
PostPosted: Sun Nov 03, 2013 9:19 pm
The fernandez ones are a little thicker. never tried laser cutting the stewmac ones, let us know if you try, if they cut cleanly. the thicker ones have a slight bead, but it ends up on top, so does not impede the adhesion.
Users browsing this forum: guitarjtb and 42 guests
